"47 346 engine question
Started by Bob R, October 13, 2009, 01:37:47 PM
Bob R
Will someone please tell me what direction my '47 346 engine turns. I want to turn the crank manually because the motor does not run.  When standing in front, does it spin clockwise or counter? Does the fan pull air through the radiator?  ( i'm guessing yes, wich would mean that it spins clockwise,yes.) Thank you,Bob
Doug Houston
Yep, it's clockwise, facing the front of the engine. I'm gonna say that all passenger and truck engines have the same rotation,  on vehicles on this continent. Sure as shootin', somebody will have an exception!
Single engie airplanes have CCW rotation, as I've often seen.
On boats, twin engines may be identical, but one of them rotates counter to the other.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
Jim Stamper
     Is it the Brush one of his later cars that turns backwards?  Help me here.
Otto Skorzeny
I think some MOPAR engines turn ccw when viewed straight on.
fward
HUGE VENDOR LIST CLICK HERE
#4
I just Googled it Forrest, and Honda front wheel drive engines run counter clock wise, Apparently. ???
Doug Houston
Quote from: Steve Passmore CLC 22373 on October 13, 2009, 06:27:30 PM
I'd expect something like that.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
