Heater problem in Cadillac Fleetwood 1978
Started by mauser, October 16, 2009, 05:09:39 PM
mauser
Dear friend.
We have here a Cadillac fleetwood 1978 and we have some problem with the heater, it always blowe cold,
what can be the problem, is it some electric or what?
Joivill
Johann Vilhjalmsson
CLC # 24743
Cadillac Fleetwood Brogham D' Elegance 1976
Cadillac Eldorado 1983
Not much info, you set it to 85 and it blows cold?  If so check the water control valve see see if you are getting circulation to the heater core, I assume the air comes out of the heater, as I said the info is limited here.
Are you sure the fan is running?  I have seen several 78's with fan problems.  One seemed to have enough 'ram air' effect to blow some when you were going down the road.
mauser
Thanks  the fan runing, but just on the defross. hi and lo not work also automatic, but we have to start the engsin to chek the water hose for the blowerwill be hot .
joivill
Johann Vilhjalmsson
CLC # 24743
