Borg Warner Vacuum Advances need assistance
Started by John Washburn CLC 1067 Sadly deceased., October 22, 2009, 05:54:13 PM
Folks,
Just given a box of Vacuum Advance units, made by Borg Warner, numbers are in the high 300's and low 400's.
Anyone got a manual on these?
Any help appreciated.
John W.
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Warren Rauch
 I have a  1978 book (not for sale) that covers up to  398. How many do you need info on? Warren
Warren,
Need info on the following vacuum advances:
V194
V339
V383
V389
V393
Any help would be greatly appreciated.
John Washburn
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Warren Rauch
 In general this is what they fit(I'll copy the pages for you):
V194 Mopar 70-72
V339 Ford 72-74
V383 Olds 75-76 350 w/Dist 1112936
V389 Cadillac 75  all Calif exc Seville
                   76 all Calif exc EFI
V393 Ford 75-78 (78 book)
  Warren
Warren,
I am hoping that you might have the time and inclination to look up 5 more of these mystery Borg Warner Vacuum Advances.
V 321
V 338
V  345
V 353
V 373
Thanks John W.
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Warren,
On the first look up try I typed in V393, was supposed to be V 392. Can you look this one up also and I promise to leave you alone.
John W.
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Warren Rauch
  I sent you some photo copies from the book. Some of what you want will be in them.This should be the rest.
  V 321 Buick 73-74 striaght 6
           Chev 71-74 4cyl
           Chev,GMC, Olds,Pont 73-74 6cyl
  V338  Ford 72-74  see copies
  V345  Chry. 75-77 318 wo/Emis leaded fuel Pkg
                   74      360 4bbl exc hi perf
                   75-77 360 w/ air pump
                   78     Calif, Hi Alt  exc Lean burn
            Dodge, PLy see copies
V353 Checker 68-72 8cyl
         Chev    69  350 w/300hp w/auto
                         307
                    70 350 w/300hp
                        307 w/auto
                    71 350 exc hi pref
                        307 w/std trans
                    72 307,350 w/2bbl
         Pont  71-72  307 w/std trans
v373  Olds 68-74  see copies
V 392  Ford prod 75-77 see copies
Warren
Warren,
Thanks you are the best. Do you want me to send you (a copy) the Hinkey-Myers catalog?
Joihn W
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Warren Rauch
  If you would send me a copy of that book ,it would be wonderful . Thanks Warren
Warren,
Will do, don't have your address, but guess it will be on the stuff you sent me.
Thanks again.
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
