1939 LaSalle battery
Started by hudson1948, November 28, 2009, 11:38:49 AM
hudson1948
Hi, Does anyone know what the correct battery is for a 1939 LaSalle. :D :D
Charles Salvato, 1948 Hudson Commodore 8 convertible, 1950 Hudson Commodore 6 sedan, 1942 Hudson Deluxe 6 coupe, 1946 Chevrolet 1/2 ton pick up
Otto Skorzeny
G2 Series Delco
Buy a new one here:
http://www.antiqueautobattery.com/
fward
HUGE VENDOR LIST CLICK HERE
Doug Houston
That will be mounted under the driver's legs, if it's the same as a '40 LaSalle I once had.
If it's a vital matter to you to have a Delco branded battery, Otto's advice above is good. I buy my batteries from Tractor Supply Co., and you should be able to get that battery there for around 70 bucks. I just bought one for my '41 Chevrolet there, and it ws about 65 bucks.
If you're going to have the car for a long time, you might even want to look onto an Optima battery, for longer longevity and high cranking power.  Nobody's gonna be looking under the front seat or floor pan!
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
Yep,
I am with Doug. On my 37 LaSalle got tired of taking the seat out to check the water level in the battery. So now the 6 volt Optima (they make one run a year for 6 volt batteries) is resting there and will not be uncovered till it goes dead. I expect it to last for at least 6 to 7 years.
Life is good.
John  W
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
