where can I buy quatertr molding Clips for my 67 CdVille?
Started by dudley peters #25677, January 03, 2010, 07:27:53 PM
Greetings all,   from this First time user to forum.
I have a 1967 Coupe  de Ville that I would like to replace the rear quater panel molding trim.  I have the trim but am reluctant to replace it without the correct molding clips in hand.  I believe that the clips may be of two different sizes because as the trim gets to the rear of the car (it is 8' long)the trim gets wider than at the front of the quater panel.
Anyone know where I can get these clips and offer any insite.
Dudley Peters #25677
Dudley Peters
Lars Kneller 8246
My 72 Eldorado required some unique clips for the trim on the doors.  I found a vendor at Hershey who had a lot of different clips, and he had some that worked. Unfortunately I don't recall the vendor's name.
Vinny 6T6
Thank you all for the response!!!!!
I shall follow up
Dudley 26577
Dudley Peters
