1960 Ignition Switch Wiring Question
Started by Jeff Garrett, January 05, 2010, 10:34:22 PM
Jeff Garrett
Gurus, we have a 1960 Coupe DeVille that has a bad fiberglass covered resistance wire that runs from the IG post on the ignition switch to the postive post on the coil.  Are you aware of a source for this wiring?  Please reply to ride2001@bellsouth.net.
Have a good day
Jeff Garrett
Jeff Garrett
1960 Coupe DeVille
Sweede64
Thomas Karlström
Jeff Garrett
Thanks Sweede64.  Actually, I have that wiring diagram.  I should been a little clearer, I'm trying to figure out if there is a supplier for this special fiberglass wire that is used in this one application.  The wire that runs between the 2 referenced points has 136 ohms resistance, not a standard piece of wire.
Sincerely
Jeff Garrett
Jeff Garrett
1960 Coupe DeVille
