Cigar Lighter 55 Cadillac
Started by Bob Kielar, January 14, 2010, 06:07:26 PM
Bob Kielar
Is there a capacitor or something that screws onto the back of the lighter or does it run directly off the battery. I got a used one and is has this round little can that screws on the back of the lighter and you can put your 12volts to this but the lighter does not work with this connected but does without it. Is it necessary ?
Keep Cruzin
1955 Cadillac Fleetwood
There is no capacitor, the "little round can" is what is screwed on to the lighter assembly from the back after the assembly is inserted in its mounting hole.  That is what holds it in place.  If you put 12 volts to that "can" once installed you may well create a dead short --- it will let you know right away.
Geoff N.
J. Gomez
Quote from: Geoff Newcombe #4719 on January 14, 2010, 09:45:17 PM
Geoff N.
Geoff,
Actually that metal piece should be the in-line fuse for the Casco type cigarette lighter, which screws onto the lighter stud. These type of fuses are rare and $$$, alternative would be to splice a new AGC type in-line.
J. Gomez
CLC #23082
Thank you, Jose.  I shouldn't assume all lighters are the same as the ones I am familiar with.
Geoff N.
