55 CADILLAC WIPER MOTOR CABLE FROM SWITCH
Started by Bob Kielar, January 30, 2010, 01:20:44 PM
Bob Kielar
I JUST GOT BACK MY VACUUM WIPER MOTOR FROM BEING REBUILT. I AM NOT SURE HOW THE CABLE HOOKS UP TO IT FROM THE SWITCH ANY HELP WOULD APPRECIATED. ???
Keep Cruzin
1955 Cadillac Fleetwood
Jack Mcilwraith
This is a drawing I made for my '55. Check the bottom portion of the page. You may have to enlarge.
Bob Kielar
Thanks for the drawing I have it hooked up. ;D How much of a turn does it take to turn the wipers on and off mine seems to be hard to turn wonder if there is a problem with the switch or cable ?
Keep Cruzin
Jack Mcilwraith
Bob, you may have to adjust the cable at the wiper motor. You may not be getting full range. With the wipers on,see if you can move the slider at all , at the motor.
John Morris #23947
While preparing many of these switches/cables for sale I had to loosen them up. First I hit the cable with good penetrant, then coil it up and soak in a coffee can a day or 2 submerged in light oil, like 10 weight. Or even 30 weight. Then turn back & forth until loose as a goose.
71 Olds 98 LS, 66 Fairlane 500 XL Convertible, 55 Packard Clipper Super, 58 Edsel Ranger, 72 Cheyenne Super, many 49-60 parts cars, abandoned "House Of Doom" full of 49-60 parts. Huge piles of engine parts, brackets, tin, Hydramatic & Jetaway parts,  thousands of stainless moldings, dozens of perfect sedan doors.
D.Yaros
Does anyone know if Cadillac used the same Trico vacuum wiper motor for 55 and 56?
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
J. Gomez
Quote from: D.Yaros on February 04, 2010, 02:27:23 PM
Dave,
The 1956 MPL shows the 54-55 using the Trico CPH-10-20, and for the 56 a Trico 72001-4. So it seems Trico had a new design starting with the 1956 models.
J. Gomez
CLC #23082
Bob Kielar
Thanks John:
                       Soaked the cable and switch in fluid film (that stuff is great) the switch and cable are as loose as an old goose. ;D Now its on to the washers.
Keep Cruzin
