'59 Heater controls
Started by David Greenburg, February 05, 2010, 01:21:44 AM
David Greenburg
I'm trying again to see if anyone out there knows what the heater control vacuum line hookups are for a non-a/c '59.  There are 3 ports; I assume they are for manifold vacuum in, the heat control valve and the firewall air door.  But which port for which function?  I only found 2 lines under my dash, and one was disconnected.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
