1929 LaSalle distributor conversion to '38 Cadilllac
Started by FRED BAUSCH, February 15, 2010, 09:45:28 PM
FRED BAUSCH
CONVERTING A 1929 LASALLE DISTRIBUTOR TO A 1938 CAD DIST. 20K miles, and 20 years after a major engine rebuild, I am doing a ring and valve job on my '29 LaSalle 328 engine. Years ago I was told that a '38 Cad dist was a virtual bolt in, and would improve performance considerably, and over the years I have accumulated '38 Cad dists and parts. Since my '29 is a driver and long distance traveler, I am not concerned about total originality. It seems that the "bolt in" description is not quite accurate. Has anyone out there done this, and can you offer hints as to what might have to be modified to accomplish this conversion? I am having trouble with the compatability of the bottom of the '38 dist, and securing it to the top of the '29 tower. Any help or advice would be greatly appreciated. Many thanks. FRED BAUSCH - - 650-592-9159
freds29lasalle@comcast.net - - - San Carlos, CA
Wayne Womble 12210
Frankly, I don't see how it would be much better than the original.
Carfreak
Have you considered Pertronix?   A friend installed it in his late 20s Ahrens Fox.
Otto Skorzeny
Wayne poses a valid point. What do you hope to gain by changing one 6v dizzy for another? Why go through the trouble for what is essentially a zero return? Am I missing something?
fward
HUGE VENDOR LIST CLICK HERE
Jim Stamper
      I assume 1929 is still dual point as was my 27 LaSalle. That being the case, keeping one set of points in tune should be easier than two sets, to say nothing of finding the older sets in NOS condition. The amount of built in vacuum advance would be a consideration, requiring some study.
      I am not saying I would make the switch, I never tried it, just that these might well be considerations. Later ignition parts are off the shelf items.
Wayne Womble 12210
For my 31 and 33, the points and rotor are a shelf item also. NAPA point sets 777 and 778. They are for a late 40s early 50s with dual points, but work well with the older distributors.  Some have to be modified just a little. I think the points on the late 20s would be the same.
