1959 Cadillac Cowl Plate Decoding
Started by bobsnhawaii, February 19, 2010, 11:38:50 PM
bobsnhawaii
If someone could help me out , i would really appreciate it. I'm looking for a online link to decode the cowl plate of a 59 Cadillac. I would like ALL the codes, trim and paint codes if possible.
Thanks Bob
PS: I have a complete list of codes for a 1960 cadillac. If anyone wants it just let me know.
Mike Josephic CLC #3877
Bob:
The easiest way to do this is for you to provide the info from your cowl plate and
I'm sure we will be able to decode it for you!  I do not know of an "on line link"
for the 59's.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Carfreak
There's a complete 59 Data Book online in the MCLC Documents Section.   Lots of other info.
Accessory Groups:   http://www.modifiedcadillac.org/documents/1950s/1959/1959%20data%20book/tn/1959%20data%20book-57.jpg.html
domer
I just looked into the 59 data dook and can't find all of my accessory codes.  E, H, N , Y.  I found the first two but not the other two (N, Y).  Any help is appreciated.
Dominique Vasquez #24943
1959 Coupe Deville http://bit.ly/1XkRuZc
1994 Fleetwood  http://bit.ly/1OTqOf1
Carfreak
Carfreak
Otto Skorzeny
Is that yours CF or is that from the MCLC files?
fward
HUGE VENDOR LIST CLICK HERE
Carfreak
David King (kz78hy)
I see an error in the 1st page of the data.
The Eldorado Brougham is correctly noted as  "P" on the LH side of the page.  On the RH side of the page they list the body style number for the 57 & 58 Brougham 7059X, not the 59 (or 60) as 59 6929.
I guess for 99 cars, does it matter?
Below is a reference shot of 59 Brougham, car 35.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
domer
Thanks for decoding that for me. Awesome info sheets you posted. So it looks like the autotronic eye that is mounted on my dash is not factory correct..bummer!
Thanks very much
dominique
Carfreak
Quote from: domer on February 20, 2010, 09:56:16 AM
I wouldn't be so certain about that - seen a lot of cars with 'factory options' not listed on the body tag.
Only way to know 100% for sure is to get the original dealer invoice.
Dan LeBlanc
Don't forget, the autronic eye could also be purchased as a dealer add-on accessory. I wouldn't think of it as a bummer that it didn't come with it from the factory.
Dan LeBlanc
domer
Thanks guys. Guess I didn't think of that. Is it possible to obtain a copy of the invoice through this site?
Carfreak
quadfins
I have never seen Autronic Eye listed singly on a data tag. But I have seen many of them on cars, including mine. They were part of an Equipment Group which, for some reason, is never indicated on the tag. I don't know why, but they are listed on the build sheet. Same with whitewall tires, and many other factory accessories included with basic or equipment groups.
I would assume that it WAS factory installed.
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
DeCou Driving Award x 4
Carfreak
Quote from: quadfins on February 20, 2010, 10:21:29 AM
Quote from: CarFreak on February 20, 2010, 01:27:39 AM
quadfins
Exactly!!!
Has anyone seen code W, R, F, or U on a data plate?
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
Barry M. Wheeler #2189
Just to confuse the issue, I have some Olds purchase order sheets from the late 1960s, and there are blank spaces scattered all over the sheets so you can write in arcane and little used accessories or options.
Code "U" for the autronic eye is rarely seen on the data plate for whatever reason.  Therefore,
just because your data plate does not show it does not mean your car did not come factory
equipped with it!  There are also other oddities about data plate information in the 50's such
as instances where equipment comes STANDARD on a particular model but still has the codes stamped on the data plate.
My 1955 Eldorado is a good example of this -- it has the codes on the cowl tag for "H" (heater), "Y" (4 way power seat with vertical lift) -- both which were standard equipment on the Eldo.  When we did the Class 15 Authenticity Manual we searched all available literature but could not uncover any explanation for this.
2004 Escalade
domer
Hello,
I just received a copy of the build sheet today in the mail from Allied Vaughn.  Looks like my 59 did in fact come with Autronic Eye from the factory along with fog lamps and door guards. Basic Group A and Equipment Group 3.   You guys were correct!!  Awesome!!
Delivery location was in Chicago IL.  Came with Firestone Black Tires.  White sidewall tires. Build date was November 15 1958.  2 license frames and Antifreeze.
As always, thanks for everyone's help.
dominique
