1941 Horn ring
Started by Dan S, March 31, 2010, 02:38:44 PM
Dan S
Hello everyone.  Looking for the sponge rubber that is between the horn button and the metal contact of the 1941 assembly.  Does anyone sell this part?  Does anyone have a nice trace outline that I can try to replicate the part so that the horn is usable (41 manual is too small to determine exact placement of notches).
Thanks!
Dan S
Doug Houston
You can buy a roll of weatherstrip sponge rubber from most good hardware stores. Granted, a whole roll of the right cross section weatherstrip is a bit much for one car, but you can't buy it in smaller quantities.
The cross section of the material is the important thing. The thickness of the "block"  of it should be around 1/4" to 5/16".
The pocket in the horn ring will tell you how to cut the weatherstrip.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
