57 cadillac fleetwood
Started by Daniel, April 01, 2010, 09:36:29 PM
Daniel
The power rear windows go down but not up. Actually they will go up if I have someone pull them up while I use the window switch.Does this sound like a do it yourself job or need tech? Any suggestions on where to purchase window motors/parts if needed? Thanks.
Otto Skorzeny
Click the link in my signature for a list of Cadillac parts vendors. Lots of salvage parts sellers. Hydro-E-Lectric might also be able to help you.
You'll need to take the panel off to check for obstructions, gunk in the tracks, etc. Spray some silicone on the guides so the motor doesn't have to work so hard.
fward
HUGE VENDOR LIST CLICK HERE
Daniel
Thanks for the reply and the extensive list!! Appreciated!
Daniel
