Loose sun visor on 75 Eldo convertible
Started by DaveShreiner CLC#23834, April 10, 2010, 07:48:31 PM
Does anyone know of a way to tighten a sun visor that won't stay up?  There is a screw to tighten but it never gets tight enough to hold the visor up.
Dave Shreiner
CLC#23834
Barry Norman
I carefully drilled and tapped mine and used a small allen screw which you can't see. The rod that goes through the visor is probably turning in the main bracket ( part attached to the header panel ) .
Barry Norman
Thanks for your advice.   :D  I have tried this but I am still having trouble, maybe because I haven't drilled deeply enough.  Does the hole have to go through the inner rod too?
Dave Shreiner
CLC#23834
You could always drill through the shaft, and insert a Roll Pin in place, plus glue the shaft in place to take up any looseness, but then, you wouldn't be able to replace it unless you drilled completely through.
Barry Norman
I drilled partially into the rod. Seems to be holding just fine !
Barry Norman
Thanks for all your help.  I did get it fixed.   :)
Dave Shreiner
CLC#23834
