GMC later developed a V6 with something like 450 CI. trucks need short engines.
That car is a Packard, not a Buick.
During this era Harlow Curtis was at the helm of Buick. He began his career at Buick as a comptroller, so he was pretty much Buick through and through. He was champing at the bit to make Buick, at least the top line Buicks, the equal to Cadillac. Even going so far as introducing a limousine. It was at that point that Alfred Sloan put his foot down. He allowed the big body for Buick, but decreed that Cadillac would also get it. That was the Series 67. Buicks always had OHV engines, right from the beginning. The original Buick engineer, Eugene Richards, patented the OHV engine used on the very first Buick. The succession to a straight 8 was a logical one. After Auburn popularised it, it became a status symbol of sorts, and created the lovely long hoods that were part of these cars. The 320 straight 8 was about the same size as competing models from Chrysler and Packard, so there is no doubting as to why they had it. By adding compound carburetion they upped the horsepower ante. The Century was created by combining this engine with the Special body to give a true 100 MPH car, hence the name. However, this did not last. They were notorious fuel hogs, and during the gas rationing of WWII, many of them had the secondary carb blocked off. Buick never went back to this system, at least until the Wildcat engines of the 60's. Flxible Bus was a separate entity from GM. Their first buses were in fact built on stretched Buick chassis, but later when more dedicated designs permeated, they retained Buick power. This lasted until at least the early 50's until they began to switch to GM Diesels. The GMC V-6 was a unique design. It was available in 3 displacements. the 305/351's for use in light duty and medium duty trucks, and a 478 cid version for heavier applications. Then there was the huge 702 V-12 which used a single block crank and cam, 4 heads, 2 intake manifolds and distributors and the reciprocating assemblies from the 351 V-6. The V-6 designs were used from 1960 through the mid 70's on Chevrolet and GMC trucks. The V-12 was discontinued after 1966 in favour of a 537 V-8 based on the 478 V-6. The V-6 engines completely superceded the 302/503 in line 6's. They also offered Toro-Flow diesels based on these engines, which were somewhat less than successful. GMC used Pontiac V-8's in some light duty applications, and they also used Buick 322 V-8's in some applications through the 50's. Mike
