1932 Cadillac v-8 Water Pump leaking
Started by 47bigcadillac, May 18, 2010, 03:21:12 AM
47bigcadillac
My water pump has developped a leak at the spot where the generator connection meets (back side of the pump).
I will remove it and re-pack it.
Has anyone a good source for packing material that would fit this type of Pump ? (1932 V-8 355B)
Anything I should watch for during the pump removal/installation and re-packing process ?
Thanks a lot
Rob
R. Brandys
1932 355B  5 pass Coupe,  Fleetwood
1935 LaSalle Coupe  5077
1947 Club Coupe      6207
Wayne Womble 12210
Occasionally I will see some of those special water pump gaskets for sale, but I use graphite seal rope available at most any good auto store. There are also packings available in the plumbing industry.
Wayne Womble 12210
I assume you know about the packing nut to tighten the gasket?
harry s
Two other things to consider; check the bushings and shaft for wear and the packing nut on a '30 V8 is left hand thread, probably the same on a '32
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
47bigcadillac
Wayne, Harry
Thanks a lot for the replies. I have never worked on such pump before.
They sell 3/16 , 1/4 and 1/8 square braided flexible graphite compression packing on e-bay.
Which size would be the best for this case ?
Rob
R. Brandys
Wayne Womble 12210
I would say 1/8, but I am not sure. You need the difference between the outside diameter of the shaft vs the inside of the nut. If I remember correctly that is about 1/8.
harry s
I just got a 1930 water pump done. The two bushings and shaft had to be replaced. I had the parts made by Pete Sanders (http://fm22.888.net/fmi/iwp/cgi?-db=PartsDatabase04-12-07&-loadframes). We used 3/16" continuious packing.
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
