Here is another area to check. I had the same thing happen to me on my 47. Followed the book on adjustments but still when I pushed the pedal to the floor, no passing gear. The problem turned out to be ME. In my quest to put a heat barrier under the carpet plus padding, I had too much of everything so the pedal was not going down far enough. Removed the obstruction and worked like a champ. So make sure when you push the pedal all the way to the floor, you are getting full throttle at the carb.
