38 LASALLE BRAKE CYLINDER
Started by JACK HARRIS, May 28, 2010, 08:34:39 AM
JACK HARRIS
THANKS FOR ADVICE IN ADVANCE seems all parts ,local at least stop at 1940 or nwer,doe any one know what is compatible with my 38 lasalle wheel cyl/masercyl #ca i maybe rebore to just oversize ,useing new size kit?
Jim Stamper
     I just bought a rebuild kit from Napa for my 1937 Cadillac 60. I have not put it in yet, but I think the counterman said his first book only went back to 1940, but when he checked an older out of service book he found they were the same. Parts books have to start somewhere I suppose, doesn't mean there isn't some overlapping. Maybe I'll get a surprize when I try to use it.  Napa , Newport, NH  603 863 9700    He got it overnight for me.    Jim
markl
Jack,
Like Jim, I relied on my local NAPA for brake parts for my 37 LaSalle.  Sloppy record keeping on my part; can't find the receipt for the MC rebuild kit, but the plastic bag it came in bore the number: 2 and then under that 0715.  I think they had that in stock!
Brand new wheel cylinders for the rear axle were  P/N 4803 and 4804.  Added bonus, these are made in USA.  Castings bear the numbers, 7565 and either #2 or #6 following a manufacture's logo (a "C"  or "G" w/ a "v" stamped inside) which I don't recognize.  Adjusters were also purchased, P/N 80562.
Mark Lowery, CLC#25216
JACK HARRIS
thanks guys ,going to town tommoro, gonna see '.jack
Jack,
When I did my 37 LaSalle I thought I remembered that later models did not fit.
When I looked it up in my Wagner Catalog it showed:
The Master Cylinder kit as #FC3629. It will fit the earlier cars 1937-1939, and 1940 60 Special.
Now later kits may have some of the same diamensions, but not the correct metal parts. So you may want to check this out a little more in detail. I believe I found the correct kit from a vendor in Hemmings.
Good Luck
John Washburn
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
markl
John,
I believe the "does not fit later production" situation comes from 1937 LaSalle having "Early " and "Late" production.  I neglected to mention to Jack that mine were evidently Late production and hence the same as the 38 models.  The quick check for wheel cylinders is that Late are 1 3/32" for fronts, and 1" for rears.
This matches the bore dimensions for 1938 for 50, 60, 60S and 65 series cars.  The master cylinder bore for those same series cars is 1", there being no mid-year production changes.
Jack,
You probably know all this and more if you took your old parts w/ you on your foray to NAPA.  But let us know in case I've given out any erroneous information.
Mark Lowery, CLC #25216
Nope,
It was specific, as I stated for 1937 thru 1939, and the 40 I listed.
Again, The bore may be the same, but the other parts, metal, are different.
Good Luck
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
mark hewitt
Take your old Master cylinder to your nearest Clark forklift parts agent and ask for part number 851820 .
it bolts straight on , amazing .
Dont hit the anchors too hard , your head will go through the windscreen.!
Mheers
Mark
Jeff Maltby 4194
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
Otto Skorzeny
Gotta love that ad copy.
Don't wait for the safety man to come around handing out citations.  Fix that forklift  Cadillac today!
fward
HUGE VENDOR LIST CLICK HERE
jack harris
thanks guys ,been on vacation, so haven't responded. all hep is appreciated,when we get home gonna get to work on car ,jack harris
jack harris
just got home. had bought the part on ebay,it was here when we arrived.looks exactly the same,gonna find out as soon as i catch up with all the grass a ;)nd weeds!thanks again.
Bought 4 of these myself a couple of years back, working fine, they were also the same type as my friends 1947 Hudson 8, You cant beat that price, a rebuild kit will cost you more.
Dan Leininger
Does anyone know if this Clark 851820 master cylinder will also fit a 1939 LaSalle 5019?
I can't believe that price either!  i have paid more for various rebuild kits.
Dan Leininger
CLC#25328
DNLaSalle
Dan Leininger
Sioux Falls, SD
1939 LaSalle 5019
1941 Packard Clipper
"Progress is made by lazy men...
looking for easier ways to do things."
Otto Skorzeny
Is the 38 MC and 39 MC the same part number in the GMPB? If not, I'm sure it could be made to work.
fward
STEVE CLC #16187
#15
The 38 LaSalle Master cylinder and 39 LaSalle master cylinder are completely different and cannot be made to fit, we know that Don't we Jack ?
steve
steve hales
clc # 16187
jack harris
yes steve we do.we cmpered 39 of steves his mountts thru the side my 38 front to rear.that cyl was aprfect fit working great,like was mentioned,don't hit em hard!thanks again ,jack. ;)
dirkdaddy
For the records, my late '37 has the 1 3/32 front cylinders, and the rebuild kits for front and rear are NAPA # 35 & 21.
Realize this is old thread, just adding info so its all in one spot. Also thanks for the forklift master cycl info, I ordered one of those today too.  ;)  My cylinders pretty gunky, leaky. I honed a lot but never got all the bad spot out, but it did feel pretty dang smooth with fingernail and it was outside where the seal edge is so hope that is enough.
Scott Philbrook
Houston tx
