1959 convertible boot
Started by baronsmokes, June 24, 2010, 01:05:54 PM
baronsmokes
Hi
The front of my 59 convertible boot is flat.The front  of  the boot looks like it slides into a slot behind the back seat.I do not have this on my car.What does this look like and where could someone find this?
Thank You
Brian Francis
Brian Francis
DaveW
Brian,
If you have a rubber bulb sewn onto the front of your boot you may be able to use the same solution I used on my '57.  The link below shows a part called a "convertible boot slide rail" I purchased on eBay.  I painted it to match my interior and screwed it to the panel on the back of the seat.  You may have to bend it slightly if you want it to match the contour of your rear seat exactly.  Good luck.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=250337431284&viewitem=&sspagename=STRK%3AMEWAX%3AIT
Dave
David Whittaker
CLC #20768
1957 Cadillac Series 62 Convertible
1958 Cadillac Series 70 Fleetwood Eldorado Brougham
1977 Cadillac Fleetwood Brougham
