Need a source for seat foam
Started by J I Garner CLC # 23406, July 07, 2010, 05:50:48 PM
I need to find a source for the foam cushions to go on the seats of my 1962 Eldorado. It has bucket seats. Any help will be  appreciated.
Jim
Jeffrey Burland
Classic Industries sells 62-63 Impala bucket seat foam for $80 per. They may be just gearing up for it since it's not in stock, but might be worth a shot if you can get them to send you some pictures and contour dimensions when they get them in. HTH, Jeff
Jeff Burland, Just one guy with too many 54-76 restorables and parts to list
https://www.facebook.com/WillingtonCadillac/
Are the Chevy, Buick, and Olds seats the same size as the Caddy? Buckets also the same? Will standard foam work for the Eldo with inserts? My foam is like dried bread. Thanks for your input.
Jim
