Cork Gasket--346 flathead V-8
Started by Thad, July 15, 2010, 02:23:55 PM
Thad
The engine gasket kit contains a cork gasket that is 2 1/2"o.d. , 1 7/8" I.D. and 5/16' thick.  Where does it go?
Thank you
Charles McMillen-#21953
Charles A. McMillen--#21953
harry s
Sounds like the front engine cover crank/pulley seal. It fits into a metal retainer and presses against the smooth surface inside the front engine/timing cover.
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
