1959 Eldorado Biarritz restoration exterior color
Started by Anthony, August 08, 2010, 08:47:41 AM
Anthony
Hello again!
I am restoring a 1959 Eldorado Biarritz, exterior color Argent. (Metallic Silver)
How do I get the correct color?
Is the color 'eye' matched? Is there a formula available somewhere?
Im assuming whatever materials used then have changed, how do I convert 1959 color componets into current day paint technolgy?
I am in Australia so Im not sure if I can just order paint from the US and import it here.
Thanks for any help
Tony
Davidinhartford
I would think any automotive paint supplier should be able to set you up with the correct colour.
Huffstutler
Not sure if this will help with the matching but you will be armed with numbers at least for mixing.
First, the factory color code is 92
The Dupont Color is called Argent Metallic and is a Lucite paint mix... 2814-L  with mixing code 882-91422-L
PPG also had a match calling theirs Argent Poly in their PPG Ditzler Duracryl  number DDL 31653
Hope that helps some?
Eric
Eric Huffstutler
