78+ ELC module repair?
Started by TJ Hopland, September 13, 2010, 11:04:37 AM
Anyone ever try to repair the 78+ Electronic Level Control module?   The one in my 80 eldo sort of works but its like there is wear or something loose internally because the setting does not stay consistent.  I remember seeing screw on the module so I wonder if it comes apart and if I get it apart will it go back together?
