Not the same starter Kris on all these different GM cars, as mentioned, the drive housing on the end is different between the different makes depending on where the starter is located in relation to the flywheel, but the solenoid on Buick and Cadillac are the same regardless of transmission 37 through 47. Most solenoid problems are caused by the points being dirty or burnt out but it looks like Bob is able to help you out here if a used one is OK.
