2nd Battery Question on a 66 Series 75 Limo
Started by randys66caddy, January 29, 2011, 11:22:57 AM
randys66caddy
I'm wondering if one of you can answer a question for me about the purpose of the 2nd battery on a '66 Series 75...
I'm the 4th owner of the car and the 2nd battery was apparently removed by the 3rd owner. I have photos of it in place in the engine compartment but my mechanic is not sure why it was required..
Randy Harris
Langley B.C. Canada
1966 Fleetwood Series 75 Limousine
CLC Member 26438
Jim Sparrow
To my knowledge it wasn't required or installed at the factory. The other "battery tray", on the left side of the radiator (driver's side) is actually there for the photocell unit for the Guidematic automatic headlamp dimming option. Note the holes right there just above the left parking/turn signal assembly. The holes are there so the photocell unit can "see" the headlights of oncoming cars & switch your lights from high to low beam. HTH    -Jim
okccadman
That area was also used for a second battery on an ambulance.  The second or back up battery is still used on newer limos with high electrical demands.
Jim Jordan CLC# 5374
Oklahoma City, OK
55 Series 62 Sedan
56 Series 62 Coupe
56 Fleetwood 75 Derham Limo
59 Fleetwood Sixty Special
66 Fleetwood Brougham
66 Superior Hearse/Ambulance
67 Fleetwood Sixty Special
68 Fleetwood Eldorado
76 Coupe de Ville d'Elegance
90 Brougham
92 Fleetwood Coupe
93 Allante
94 Fleetwood Brougham
02 Eldorado Commemorative Edition
