1960 CDV rear suspension
Started by Ivan Zanatta, February 01, 2011, 01:30:57 AM
Ivan Zanatta
I would like to know the dimensions of the rear lower control arm bushes 0n a 1960 Coupe Deville.
These are the ones below the diff housing. Are these the same on any other GM product?
Ivan Zanatta
Warren Rauch
 These bushings are only used on 58-60 exc 75 ,CC  ;61-64 exc CC & 1965 series 75 Cadillacs.They are larger in diameter and longer  than was normal for the part. From a 1973 TRW book . Main tube OD is 2.311" with a shoulder 2.344" Diameter . Length overall 3", main tube 2 25/64": shoulder 25/64". Inside diameter .505": The rubber extends beyond the flange 11/32". The flange is on the shoulder end and adds to the overall length.
   The next closest I found was for 1965-up Cadillacs (same use). It  is only 1.858 in Diameter so it would need a very thick bushing to be useable.Warren
Ivan Zanatta
Thank you Warren, that's exactly the info I was after!
Ivan Zanatta
