'95 Seville Tailight Question
Started by Mike Josephic CLC #3877, February 18, 2011, 11:25:16 PM
I have a '95 Seville SLS which has a problem with one of the rear tailights accumulating
moisture in the tailight / backup light housing.
The inside is "fogged" with beads of water on it.  This seems to be a common problem
with these as I've seen others with it.
Questions:
-- How do you dry it out?
-- How do you seal it up to prevent this problem from reoccuring?
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Come on fellows!  Somebody out there in Cadillac land must have an idea on this.
Can I hear from one of you former technicians that frequent this forum?  Any advice
welcome.
2004 Escalade
I got an 05 that started doing that after a minor accident.  I cant find any signs of any sort of damage.  I was thinking of taking it apart and letting it dry then maybe putting one of those little 'do not eat' packets in there to be sure all the moisture is out and see if it does it again.  problem is I only notice it and think about it when I am on my way out somewhere, if I saw it when I got home there is a better chance I would remember to fix it.
The only way condensation is going to get in there is if the lamp socket is open to the elements, or there is a crack, or a joint has come loose.
The best way to find out if there is a suspect joint is to pull it out, fill it woith water, and see where it is leaking out, apart from the lamp hole.
Eric S. Maypother #15104
Another thing, maybe drill a little hole in the bottom so the moisture can come out. I sell used tail lights, some have small drain holes, some don't so it wouldn't hurt to have 1.
Eric :)
1990 Cadillac Brougham
David King (kz78hy)
My vote is to get the lamp dry, inside and out.
How about warming it up.  Assuming it is removed from the car.
If the lamp is warmed to around 140F or so, and you identified where the breach was, apply some sealant to that area and allow to cool in a dry place.  I would do this with the lamp socket hole plugged well, so the cavity is sealed.  During the cooling process, the sealant should be drawn in by the vacuum created.
Just crazy thinking on my part.  A lot like canning green beans.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
