1960 cadillac fuel gauge
Started by bryan rosen, February 23, 2011, 11:50:51 PM
bryan rosen
Has anybody had any experience fixing an erratic fuel gauge on a 60
cad?
quadfins
It depends on what is causing the error.
My problem was solved when I made sure of a proper ground from the sending unit to the frame, back by the tank.
But this was on a '61.
Jim
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
DeCou Driving Award x 4
Randy George CLC#26143
I have had good luck by pullling the cable out from the transmission side and grease it with multi purpose bearing grease and the irratic needle and noise went away. Assuming no gear damage or major cable fraying exists.
Randy
Sorry I am such a moron. Had speedometer on the brain this morning!! I did however find as was previously mentioned making sure there is a good ground at the tank sending unit is essential. Pardon my intrusion!!
Randy
