56 horn ring
Started by dplotkin, March 08, 2011, 07:11:50 PM
dplotkin
So how do I tighten the horn ring? Manual says there are two allen screws accessable behind the steering wheel but I don't see where. Anyone?
Dan
60 Buick Electra six window
60 Chrysler 300 F Coupe
62 Pontiac Bonneville Vista
63 Chevy Impala convertable
63 Ford Galaxie XL fastback
65 Corvette convertable 396
68 Chrysler New Yorker
J. Gomez
Dan,
They are tucked inside the horn ring cross member at an angle and at opposite corner, Fig 5-12 will show the approximate location below the cross member.
HTH
J. Gomez
CLC #23082
dplotkin
So behind the wheel at the 3 & 9 0'Clock positions?
J. Gomez
Dan,
That is correct..! Real hard to see them  :(
Good luck..!
J. Gomez
CLC #23082
dplotkin
I'll tend to that Saturday, thanks.
Dan
carguyblack
I'll add my 2 cents worth as I have had my steering wheel off so many times the threads are worn out! If you look on the backside of the steering wheel, where the allen set screws are there is a slight cutout indent in the plastic on opposite sides where the spokes originate. The allens are deep inset at those spots. Get a really bright flashlight and spot them first before you go digging around. I find that proper light is 90% of the battle. Especially with my old eyes. Once you find them, you'll say "Oh yeah. Now I know what they mean!" You'll need to get on your head and be a contortionist for a bit to see what I'm talking about.
Chuck
Chuck Dykstra
1956 Sedan DeVille
1956 Coupe DeVille (2 sold)
1957 Oldsmobile 98 (sold)
1989 Bonneville SSE
dplotkin
I got under there Saturday afternoon with my allen wrench set & a small flashlight and in less than a minute I tightened them both, horn ring now to spec, thanks for the advice.
Now it's on to my second water pump in 5 months, looks like I was sold a bad rebuild. After that the hydramatic comes down for a redo and I will hopefully be ready for the season.
Dan
