OBD1 scanner
Started by DaveShreiner CLC#23834, March 09, 2011, 01:28:35 PM
Is there an OBD1 scanner that can help with engine repairs, e.g., setting the voltage on the throtle position switch in 1988-92 Cadillac Broughams?
Dave Shreiner
CLC#23834
You can us a volt meter tapped into the correct wires on the tps, plenty of info out there on the exact connections. Or use the obd system,  a site search here may have it or caddyinfo.com
Thanks for the advice.  I will try to find the right connections in the manual.  I did try a search for the OBD1 here and got no results.
Dave Shreiner
CLC#23834
