Broken Hood Release Cable - 91 SDV
Started by okccadman, April 07, 2011, 09:05:39 AM
okccadman
Any suggestions how I can get the hood open on a 91 Sedan de Ville with a broken hood release cable?  Apparently it broke at the latch assembly under the hood because the cable is still attached to the interior pull handle.  From underneath, you can see and access the secondary release but not the primary. It is on the inside of teh core support.
Does anyone know if you can remove the grille and possibly activate the latch that way?  I think i can get to all of the grille mounting screws from underneath.
Jim Jordan CLC# 5374
Oklahoma City, OK
55 Series 62 Sedan
56 Series 62 Coupe
56 Fleetwood 75 Derham Limo
59 Fleetwood Sixty Special
66 Fleetwood Brougham
66 Superior Hearse/Ambulance
67 Fleetwood Sixty Special
68 Fleetwood Eldorado
76 Coupe de Ville d'Elegance
90 Brougham
92 Fleetwood Coupe
93 Allante
94 Fleetwood Brougham
02 Eldorado Commemorative Edition
