Author Topic: Wanted : Vacuum schematic for Cadillac 1964 w/ Master Switch  (Read 1710 times)
Offline Cadillac1955
« on: April 16, 2011, 08:11:41 AM »
Im looking for a vacuum schematic for Cadillac 1964 Climate Control A/C with the Master Switch
« Last Edit: April 16, 2011, 04:50:31 PM by Cadillac1955 »
Andrè Aga
Cadillac Coupe de Ville 1955
Cadillac Coupe de Ville 1964 "The Apollo"
Cadillac Conv. 1965
Warren Rauch
  • Guest
Re: Wanted : Vacuum diagram for Cadillac 1964 w/ Master Switch
« Reply #1 on: April 16, 2011, 10:43:15 AM »
 I know they must have made an oversize diagram like you need. (I have non a/c and electric) But these are nothing more that the smaller ones that are in section 13 of the 1964 shop manual.
 I also found a copy of the Student book for the 1964 Training center a/c course. It isn't a lot different than the shop manual either.Just rearranged .The Jan 1964 Roundtable filmstrip " Weather Forcast" also dealt with A/c, but not in as much detail.Warren
« Reply #2 on: April 16, 2011, 03:16:42 PM »
I wonder if You have and can post a Exploded schematic from any Serviceman manual?? The Master Switch came a little bit later, so I cant locate it in the Shop Manual...
« Last Edit: April 16, 2011, 04:51:04 PM by Cadillac1955 »
Andrè Aga
Cadillac Conv. 1965
Warren Rauch
  • Guest
Re: Wanted : Vacuum schematic for Cadillac 1964 w/ Master Switch
« Reply #3 on: April 17, 2011, 08:34:54 AM »
  The term Master Switch does not appear in the 1964 literature. So I'm assuming you are refering to the comfort control panel on the dash. Look at fig.13-17 in the 1964 shop manual. near the center is a blob with the numbers 1 thru 5 on it. That I think is what you are looking for , even though it is labeled "vacuum valve on control head"
 In the May 1965 issue of the Serviceman , there is a new kit offered.Part #148 4983 it is called a Master Switch kit for 1964 a/c systems. It calls for using it in cases where the master switch has failed. It does not give details of the kit and says that ,details are included in the kit. Warren
