G'day Jeff, Sometimes what may be required is a bit of a CRC soak around the connection (overnight) and then a very careful bump or pry from the underside of the arm with a wooden block or wedge preferably on the opposite side of the spring loaded bit that you are pulling with all your might over the cam ( use a wooden edge so you don't bruise the soft edge of the chromed diecast wiper arm end). . . . Easy right ??
Just be careful cos you can be pulling and wiggling away on the arm and BANG !!!! off it will pop and you can easily scratch expensive paint.. . or worse knock over your bottle of beer that you have resting on the fender. So best to also put a few blankets down and get your wife to hold your beer.
Good luck . Regards. Q
