1954 w/PB losing brake fluid
Started by phildeville@cox.net, May 02, 2011, 02:39:11 PM
phildeville@cox.net
My 1954 CDV keeps "losing" brake fluid.  About 1/2'' in the reservoir per 200 miles.  The hydro-vac, master & all 4 wheel cyl's are dry & show NO signs of leaking.  Could it be getting pulled thru the PB vacuum line & burned in the engine?  The brakes work OK & the car stops just fine.
Phil
Phil Terry  CLC# 15270
Mike Josephic CLC #3877
Phil:
Yes, your hydrovac is probably leaking internally and the engine is sucking
brake fluid in via the vacuum line.  This is a relatively common problem on
old units.
If the booster has never been rebuilt, looks like it time to do so.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
phildeville@cox.net
Mike,
I had hoped you would chime in on this thread.  The unit was rebuilt 2 years ago.  It was an exchange part from Arizona Vintage Auto Parts in Phoenix, although I found it in Hemmings.  It was advertised with a 3 year warranty & I will soon see if that is true.
Phil
Coupe
I'd check the vacuum line to see if it's wet. If you're losing brake fluid thru engine you should see some white smoke. If it's a slight leak may be not.
1957 Coupe de Ville
1993 Allante
1949 Jeepster VJ-2
CEC #20099
Phil; I have had several 55`s with the Hydrovac. Yes, the engine vacuum is pulling the brake fluid in, & burning it. If you are using DOT 3 Fluid, this will not cause damage. If you are using Dot 5 silicone, you are in serious trouble, as Silicone turns to sand inside the engine, & will destroy the engine. Your booster rebuild is obviously defective. Get it redone by a competent shop.
c chleboun #20099
