ember color dip needed for bulbs
Started by Stinson, June 09, 2011, 11:12:33 AM
Stinson
Hello. Do you know where I can purchase some ember-color-dip for some small 6-volt clear bulbs. I would like to convert a set of small lights for use as turnsignals.
Thank you,
Ty Stinson
CLC22330
Ty Stinson
'37 Cad 8519 Touring Sedan V12
CLC22330
Bruce Berghoff -#1476
Ty..You can mix your own with clear laquer and add some Yellow/Orange laquer , or vegetable dye to tint to any degree of amber you desire. Mix up a small jar partially full and dip to your heart's content. If you don't like the density you can always add more coats ...or strip, adjust your mix, and re-coat ! Dip-de-doodle !
Stinson
Many thanks Bruce!
Ty Stinson
CLC22330
Ty Stinson
CLC22330
I did this and used industrial/municipal yellow in a spray can , works ok, just a lite coat though.
Ty...If you want to eliminate the mess of paint completely , you can go to an electrical rental outfit that caters to treatrical lighting  and buy a small sheet of transluscent amber gel acetate and just wrap your bulb with it. Theatrical gel is flameproof and is available in several shades of amber. Cost is about a couple of bucks a sheet. BB
Stinson
Thanks Bruce,
Could that be applied to the back side of the lense?
Ty Stinson
CLC22330
Ty Stinson
CLC22330
Sure...Just stretch it under the lense as you are installing the screws...or use a very thin strip of double face scotch tape along the outside edges . Remember..You don't want anything flammable to come in contact with your bulbs. The theatrical gels can safely lay directly against the bulb with no problem ! bb
