Question on 85 Eldo
Started by Sllack, June 21, 2011, 08:56:41 PM
Sllack
I have had my eye on an 85 Eldo since about 85...
If I were to find a very well maintained low mile original today, could I make it a daily driver?
What weaknesses does the car have, stuff I should look for when buying?
Thanks ahead.
Signed JKopra
1973 Fleetwood Eldorado Convertible
The biggest problem will be the 4100 engine, which put so many of that era Cads into the junk yard.  Buy an 80 and get a nice reliable 368.  A 79 has a good Olds 350, but the fuel injection can be troublesome.  The 81 has the 8/6/4, though it can be disconnected.  The easiest to maintain will have the least electronics, a 79 Toro or Riv have a good 350 with no computers.  Those cars certainly can be a driver, I've had one since 81.  They are twice as much work as RWD.  Your driver will need a new timing chain & brake overhaul.  Make sure you maintain good boots on the half shafts, I keep a spare set.  good luck, Bruce Roe CLC # 14630
AHBrown
By the time the '85's rolled around, GM was well aware of the problems of the HT4100 engine, and the later '85's are more dependable then earlier engines.  Although many of the prices are in the 10,000+ price range, I believe that is far too much, considering the history of the engines.  How much is the owner asking?  Oh yes, they do make great daily drivers, if the Price is Right.
Tim Pawl CLC#4383
1985 Eldorados with VIN FE623772 or higher had all the latest 4.1 fixes inplace.....better gaskets and cast in engine crossbrace stiffeners.
Tim Pawl CLC#4383
Why an 85 specifically?    Very similar body and interior over the whole 79-85 run.   And like someone pointed out the Toro's and Rivs were the same body but with either the Buick 3.8 or 4.1 or the Olds 5.0 4bbl V8.
Im not afraid of a 4100 but I love my diesel also so take that for what its worth.
Sllack
I have an affection for the 85 because a buddy of mine owned one in 89, and I got to drive it from Buffalo to Atlanta and back again. It was one of the best road trips I ever had.
Thanks for the advice. There was one for sale in Vegas with under 40k miles I think, it looked like new and was 7k obo.
Signed JKopra
