My 1958 CDV has a hesitation problem, it stalls for a few seconds when accelerating, acts just like the accelerator pump is bad. It has a rochester 4bbl that I have taken back to the carb shop for another rebuild, new pump check balls etc, no help. I have bent the rod to the acc. pump longer and shorter trying to take up any slack etc. When first taking off after restarting, even when hot, it stumbles badly then gets a little better but still hesitates every time you hit the gas. I have an electric fuel pump as well as the mechanical (for priming purposes-same problem with just the new mechanical pump), a new coil, points,condensor ,plugs and wires.
I have set the timing to specs, and even tried advancing/retarding a bit. Vac. advance is hooked up-tried without it too.
The cap and rotor have low miles, but I'm going to replace them today to be sure and the resistor as well. I have been racking my brain trying to fix this problem. Any ideas?
