V16 engine removal
Started by KD, August 08, 2011, 05:10:34 PM
KD
I'm getting ready to pull my engine out and I want to know where are the best pick points?
I have the body off and could pull both the engine or just the engine. Any suggestions?
Ken D
Ken Dennison
1935 Auburn S/C Cabroilet
1929 Ford Closed Cab Pick Up
1960 Austin Healey Sprite
KD
HELP. Any suggestions?
I'm thinking I'm going to have to build some brackets that I can use on the head using the head bolts to fasten to and lift that way
Ken Dennison
Jeff Trahan
I'm getting ready to take the engine out of my 1938 V16 and I need some advice on how to do it. Should I disconnect at the flywheel or take the transmission out with the engine in one piece?
Thanks.
Jeff Trahan
#28564
1938 Cadillac V16 9033
1947 Cadillac 62 Convertible Coupe
1958 Cadillac Biarritz
Brad Ipsen CLC #737
Not that it couldn't come out as a unit but I have always taken the trans out first.  Easy to do and the engine has 4 mounts so it is stable with the trans out.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
