Crankcase pressure regulator, breather cap and valve
Started by Rick Biarritz, August 17, 2011, 01:30:05 PM
Rick Biarritz
I’m looking for these 3 parts on Rockauto.com. Can’t seem to find them. Probably because I’m not sure what category (engine, drivetrain, etc.) they fall under. Anybody out there know? Is crankcase pressure regulator a fancy term for PCV valve?
83 Eldo with the 4.1
Never heard of a " crankcase pressure regulator" this must be a pcv valve, where did you get that term?  Oil fill cap? if So Napa should have all of this.
Rick Biarritz
These terms are from the owner's manual.  I'll double check.  Thanks.
