hazard relay 76 CDV
Started by jeff elliott CLC #23590, August 26, 2011, 01:09:41 PM
hi all,
I need to replace the hazard warning flasher relay in my 76 CDV. the item fitted at present is a 2 pin thermal unit, HD 552 manufactured by Ideal Corp.
I can purchase from the states,however, for such a small item that costs a few $, shipping costs to the UK would appear to be in the $22 range.
therefore I am hoping to purchase a relacement in the UK, does anyone know of any cross reference parts that would be compatible, or what wattage unit is required to keep the flashes per minute as standard.
regards Jeff
