57/58 Brougham brake linkage
Started by INTMD8, August 27, 2011, 08:29:08 PM
INTMD8
Looking to see if anyone happens to have a picture of how the stock brake booster is connected to the brake pedal linkage and how it's actuated.  Thanks!
I don't know if this picture can help. The booster is only connected by a tube from the master cylinder; then the amplified presure is distributed to the wheel cylinder from another tube coming from the booster.
Roger
INTMD8
Thanks Roger. That does help but more specifically I was looking to see how the mechanical linkage connected to the booster.
I have a rod coming off of the brake pedal that goes through the firewall which attaches to what looks like a bellcrank type assembly but it's all just hanging there. (and I can't visualize how it would work).
David King (kz78hy)
#3
Hi Jim,
Look on page 8-6 of the 57 service manual as it has a detailed drawing of the pedal assembly.  On the next page, it shows the complete system.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
INTMD8
Thanks David, I should have looked there.  Interesting system in how it's a hydraulically actuated booster. I was trying to picture how the pedal would mechanically actuate the booster like in later cars but that is not the case.
