1953 Cadillac Coupe gas tank
Started by jst, September 25, 2011, 07:52:30 AM
jst
Hi
Does anyone know who makes a high quality (baffled) gas tank for a 1953 Cadillac Series 62 Coupe ? The one I have now looks like a recent replacement (I just got the car). The guage registers but the needle moves constantly. I replaced the sending unit but to no avail. Is there a cure for this or does the tank need to be replaced ? Any help would be appreciated.
Thanks    Joe T     jusmct@att.net
CLC #27640
USMC  63-68
1953 Cadillac series 62 COUPE
Quentin Hall
Check the tank to earth wire as it will register full if you remove the earth (ie resistance). If earth wire is bad connection it may cause the erratic reading.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
jst
CLC #27640
USMC  63-68
