1957 cadillac 86 series
Started by 57 hearse, October 14, 2011, 09:22:42 PM
57 hearse
hi i have a 86 series commercial chassis and i need a rear brake drum for it i found a 1953 commercial chassis and would like to know if the drums will interchange with a 57
B Macy
Bob Hoffmann CLC#96
The MPB shows 56 to 59 CC only. This is another case where Cadillac forced customers to buy the hub AND drum assy. And of course LH & RH were different because of the studs. Hopefully someone will know the interchange on the drum ONLY after you knock out the studs & separate the 2. It might be the same as a front drum,after you separate it from the hub also.
HTH, Bob
