Antenna questions 1948
Started by amc6476, October 28, 2011, 02:34:09 PM
amc6476
I have a 1948 series 62 sedan with vacum antenna. My can't go all the way down as the mast is to long. Is this how the antenna shall be for a 48 car?
Tom A. Wold
PHIL WHYTE CLC 14192
As far as I know that is what all the vacuum antennas were like - my 1954 is like that.
Phil
Caddy Wizard
That is correct.  When in the "down" position, the 48 antenna mast still sticks up some from the fender.  Worst thing about that is that it causes problems with car covers.  Other than that, I don't see any downside to it at all.
Art Gardner
Art Gardner
1958 Eldo Seville (2/3 done)
amc6476
Thanks for the replies :D
I'll then have "only" left too fix the vacuum function on the antenna. Since it must be the correct one for the car.
I do agree that it makes it a little more difficult with car cover.
Tom A. Wold
Jeff Hansen
FWIW on the car cover issue, I cut a small hole in an old tennis ball and slip that over the top of the antenna mast before I put my car cover on.  It definitely saves wear and tear on the cover.
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
Richardonly
My 1948 Fleetwood does NOT go all the way down either.  It stays up about 9 inches to a foot.  ( Just a rough estimate.)
1948 Cadillac Fleetwood 60S
1995 Jaguar XJ6
