Author Topic: Removing running board rubber  (Read 1649 times)
Offline KD
  • 1940 Cadillac 9033 V-16
  • CLC Number: 26801
  • Name: K Dennison
« on: November 10, 2011, 05:29:37 PM »
Does anyone know of an easy way to remove the running board rubber. I'm using a heat gun and a chisel and it's killing me, it's really stuck on. HELP!!!!!!
Ken D.
Ken Dennison
1935 Auburn S/C Cabroilet
1929 Ford Closed Cab Pick Up
1960 Austin Healey Sprite
Offline Hankk17
  • Name: Hank Kuczynski
Re: Removing running board rubber
« Reply #1 on: November 10, 2011, 06:43:27 PM »
whenever I've dealt with removing rubber like this I've always gone the opposite way - cold.  heat makes the rubber super pliable and it'll fight you every step of the way.  Try getting a can of compressed air and invert it.  make sure you don't have any open flames nearby and blast the hell out of the running board and then see if you get better results with the chisel.  also DON'T inhale the fumes..  wear a mask for sure.  Other than that you're probably looking at the caustic chemical route which will be way messier and a whole lot stinkier.
note - I've never done this to a running board ever.  it's just a thought.
Wherever you go... There you are
Offline Alan Harris CLC#1513
  • CLC Number: 1513
  • Name: A Harris
« Reply #2 on: November 11, 2011, 12:11:04 AM »
I once had to remove the rubber from the accelerator pedal of my 40 LaSalle.
Lacquer thinner softened up the rubber so that it was wasy to scrape off.
I let it soak over night.
Offline Glen
  • CLC Number: 727
  • Name: Glen Houlton
« Reply #3 on: November 11, 2011, 12:36:14 AM »
Where are you applying the heat?
I would use a propane torch and apply the heat to the metal backing.  The rubber should melt and peel of fairly easy.  Too much heat could start the rubber burning so be careful.
I have not tried this on running boards yet, but I have used this method to remove the rubber from the front suspension bushings.  They slid out with little effort.
Glen Houlton CLC #727
CLCMRC benefactor #104
Offline Bruce Berghoff -#1476
  • CLC Number: 1476
  • Name: Bruce Berghoff
« Reply #4 on: November 11, 2011, 07:07:22 PM »
Ken...If you're preparing the surface to get it ready to bond a replacement covering, you might do better by leaving a thin coating of the old rubber on the metal surface if it is still bonding well. I've used a coarse aluminum oxide grinding disc and cut the old rubber down to a thin smooth surface, and then used a high bond industrial rubber cement to laminate my new covering right to the old rubber. It's not an indoor project, but with the right disc you can make quick headway outdoors with the right mask and protective gear. bb
Offline KD
  • CLC Number: 26801
  • Name: K Dennison
« Reply #5 on: November 12, 2011, 05:56:37 PM »
I'm going to get my running boards powdercoated so I need them to be really clean before the sand blasting.
Ken D
Ken Dennison
