1960 - 390 cylinder compession range?
Started by Larry McGee, November 22, 2011, 12:31:11 PM
Larry McGee
Working through a few problems. Took the Convertible to a transmission shop to get it to downshift. They have stopped any further troubleshooting until they get a different carb and what they see as a problem.  They measured the compression of all 8 cylinders on a just rebuilt engine. All measure between 105# - 120#.  They think it should be close to 165#.
Any thpoughts on this.
Does anyone know of a place I could buy a rebuilt and tested carburetor (Carter AFB 2952)?
Thanks for your help and advice - Larry McGee
Coupe
1957 Coupe de Ville
1993 Allante
1949 Jeepster VJ-2
Remember compression readings are dependent on engine cranking speed and whether the throttle was held open.  Your carb is wrong or can't be rebuilt?
Alan Harris CLC#1513
How many miles are on the rebuild? It is possible that the rings are not yet seated and that the compression will come up.
Was the engine at operating temp when it was tested? This makes a big difference.
Finally, I would try a different gauge before tearing down anything.
R Winchell
Best carburetors and service are at Pony Carburetors   John 575 526 4949   112 Westgate St Las Cruces NM 88005 All will have correct colors, screws, shields, and tags. All are run tested on floor engines before shipping. He will tell you which one is correct for your car.
                            Bob W.
