1952/53 gas pedal info needed.
Started by Bob Hoffmann CLC#96, November 27, 2011, 04:22:11 PM
Bob Hoffmann CLC#96
Does anyone have a gas pedal off of the car?
I need the casting # on the lever.
Thanks.
Bob
Bob,
I have one off a 52 I parted out years ago, surpised I found it on the first try.
Can't seem to locate the casting number. Would it be on the arm going thru the firewall?
John W
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Bob Hoffmann CLC#96
Hi John,
It's on the gas pedal arm that connects to the linkage.
HTH, Bob
Bob,
Will clean  it up tomorrow to see if I can find it.
jw
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Quentin Hall
Bob, I went thru hell and high water to locate two of them for you. Neither have anything on them numberwise. Are you trying to ID one. Post a pic and I will do my best. Q
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
Bob,
Cleaned off the gas pedal arm, and yes there is a stamped number on it.
Tha answer is:
925
John W
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Quentin Hall
Well I'll be darned. :-[ I just read John's  discovery and was so incredulous that I went back outside and got the wire brush and gave them both a good scrub in the sunlight and there it was. . . 9 bloody 2 bloody5.  :'(One thing I notice is that one arm is steel and the other cast alloy :o??
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
57 Biarritz
Quentin,
he,he,he.... and you get no extra credit for using big words...
John W
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
Bob Hoffmann CLC#96
John & Q,
I'm glad you both agree.
Thanks to both of you.
Bob
