Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
portable compressor?
All Cads
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: portable compressor? (Read 1403 times)
Hankk17
Name: Hank Kuczynski
on:
November 30, 2011, 11:35:48 AM »
I've managed to score some '73 eldorados locally in a barn and am going to pick them up Saturday with a friend. The tires are all flat, but some look like they may hold air. anyone have a recommendation for a decent portable compressor? something battery operated as this barn has no power to it at all.
Logged
Wherever you go... There you are
Re: portable compressor?
Reply #1 on:
November 30, 2011, 11:40:18 AM »
Hank,
Depending on how many tires you intend to fill it's going to have to be a big battery. I personally use a regulated CO-2 tank for temporary tire inflation. 10 pounds of CO-2 fills a lot of tires and a battery driven compressor takes a lot longer to work.
Logged
72 Eldo Cpe (now cruising the sands in Quatar)
Hankk17
Reply #2 on:
November 30, 2011, 11:50:13 AM »
that's an interesting idea.. but why C02 and not regular air?
Logged
Reply #3 on:
November 30, 2011, 09:56:08 PM »
CO2 has been liquified and thereby condensed, so you get a greater weight of gas in the cylinder. It is under extremely high pressure, so a regulator is needed to drop the pressure down to the 30+ psig you will need for the tires.
Logged
Reply #4 on:
November 30, 2011, 11:22:14 PM »
Those little battery and lighter powered compressors take forever to fill an empty car tire if you are lucky. There is no chance of filling one with a loose or leaky bead. If you do get a tire filled they wont likely last long enough to fill another one.
Is there power anywhere near by? I would bring a regular compressor, fill it, take it to the cars fill as many tires as you can, take the compressor back to where the power is, fill it again, and repeat till you are done. If you dont own a mobile compressor get one of those portable tanks and fill it where ever the closest place is. Those 10 gallon tanks will usually fill 2 car tires with enough air to roll the car (s).
Do any of these cars have decent interior stuff? If so I call dibs on any red stuff you are selling.
Logged
StPaul/Mpls, MN USA
73 Eldo convert w/FiTech EFI
80 Eldo Diesel
90 CDV
Hankk17
Reply #5 on:
December 01, 2011, 11:00:53 AM »
hah TJ! that's ultimately what I'm after too - a red interior. Sadly, none are red but for now I've got enough bits that are blue to put together a decent blue interior to replace the horrible tan that's in my '72 now. That plus I need convertible parts and one may actually have a '71 engine in it. I've been looking into 10 gal portable tanks - I think I'll do that. Its going to be an adventure, that's for sure.
Hank
Logged
Reply #6 on:
December 01, 2011, 11:12:44 AM »
If this is truly out in the middle of nowhere and its just not going to be practical to go to power or another compressor it may be worth renting a gas powered compressor for the day. While not ideal the ones rental places have for air nailers and such will do a better job than the battery ones. Also dont get the idea of using a generator to try and run a decent size compressor, I found out that unless the generator is really big and the compressor is tiny you end up buying a new motor for your (or your friends) compressor after a few minutes of operation.
Best thing tools I bought for this stupid habit of buying dead Eldorados is:
8000 lb capacity trailer with working brakes. Next trailer will have that little bend at the end to aid in loading.
3/4 ton or larger truck
electric winch
10 gallon air tank
big hooks (these alone have saved me hours of laying in the mud trying to feed chains under a car)
Logged
StPaul/Mpls, MN USA
80 Eldo Diesel
90 CDV
Glen
CLC Number: 727
Reply #7 on:
December 02, 2011, 12:09:57 AM »
I inherited from my father an adapter to use a cylinder of the engine as an air compressor. You remove a spark plug and screw in the adapter. It has a check valve to allow air in without using air from the intake manifold. It has a long hose to run to wheel on the car and then some.
I’ve seen him use it several times. The engine runs rough but it works well.
I have not seen one of them for a long time.
<ramble mode = off>
Last Edit: December 02, 2011, 12:11:56 AM by Glen
Logged
Glen Houlton CLC #727
CLCMRC benefactor #104
Reply #8 on:
December 02, 2011, 08:56:19 AM »
Interesting concept. Wouldn't you end up with a nice explosive air fuel mix in your tire?
Logged
StPaul/Mpls, MN USA
80 Eldo Diesel
90 CDV
Dan LeBlanc
Reply #9 on:
December 02, 2011, 10:54:50 AM »
Some of the offroad guys have the old York style a/c compressors mounted underhood on their off-road vehicles. I guess they'll flow enough air to even operate an impact wrench.
Logged
Dan LeBlanc
Glen
CLC Number: 727
Reply #10 on:
December 03, 2011, 01:02:41 AM »
Quote from: TJ Hopland on December 02, 2011, 08:56:19 AM
I asked the same question and my father gave me the answer:
No because of the check valve in the adapter. It allows outside air into the cylinder vice air/fuel from the intake manifold. It actually kills two cylinders because the outside air also flows into the intake killing the next cylinder.
I’ll see if I can get a picture.
Logged
Print
Pages: [
1
Go Up
« previous
next »
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
