1956 wiper motor
Started by FabCad, December 05, 2011, 02:03:54 PM
FabCad
I'm having trouble getting the wiper motor on my 56 Cad to operate properly. When I turn the control knob on, the wipers move outward. Then when I turn the control knob off, they move back. But they don't stay in motion. However, when I briefly disconnect the vacuum line to the wiper motor and then reconnect it, the wipers go back and forth and work just fine. Any reason for this?
1948 Sedanette
1949 Convertible
1950 Convertible
1957 Biarritz
1960 Convertible
Does the wiper motor stay running once you reconnect the vacuum hose or does it stall after a while?
FabCad
#2
Let me double check and get back....
1948 Sedanette
1949 Convertible
1950 Convertible
1957 Biarritz
1960 Convertible
FabCad
#3
When I reconnect the vacuum hose, the wiper motor operates only for a few seconds and then stalls.
1948 Sedanette
1949 Convertible
1950 Convertible
1957 Biarritz
1960 Convertible
Then your wiper motor is leaking and should be repaired. There are companies in the US who do that.
With an external vacuum source, you could confirm my "diagnostic". If you have a more recent car with cruise control operated with vacuum, take your wiper motor out, connect it to the vacuum source and try to stop the movement. If the motor is good, you should not be able to stop it by hand.
Jay Friedman
In my opinion Ficken's Wiper Service, www.wiperman.com is the best wiper motor repair shop.  They did an outstanding job on my '49's.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
carguyblack
Concur with Jay's opinion. They did my 56. My wipers will shove aside a dead cow!
Chuck
Chuck Dykstra
1956 Sedan DeVille
1956 Coupe DeVille (2 sold)
1957 Oldsmobile 98 (sold)
1989 Bonneville SSE
FabCad
#7
Thanks Roger, Jay, and Chuck. I'll check out Flicken.
1948 Sedanette
1949 Convertible
1950 Convertible
1957 Biarritz
1960 Convertible
