'61 convertible windows will not go all the way up
Started by willits, December 13, 2011, 10:39:48 AM
willits
I am putting the windows back in the doors of my ’61 convertible and have run into a problem.  I installed the regulators and the windows with no problem, but regulator runs out of travel and the windows will only go halfway up.
The only thing I can think of is that I have mixed up the right and left regulators.   I did take the motors off the clean and grease them.  I would have sworn that I did them one at a time so I didn’t mix them up, but it maybe I did them at the same time.   I wanted to check here if there might be other reason for this before I go and take them all apart again.
I am attaching a picture of the door where you can see the regulator installed.
Thanks for any feedback.
Peter
Peter Willits
1958 Coupe DeVille http://bit.ly/1O6BGVu
1961 62 Convertible http://bit.ly/1O6BHst
2008 STS-V http://bit.ly/1O6CI3P
quadfins
Page 15-30 of the shop manual has a diagram of the system. If you look at it, you might be able to campare with how yours is installed, and note any errors.
If you don't have a shop manual, email me at home (I'm listed in the Technicians" section, and in the Directory) and I'll send you a scan via email.
Jim
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
DeCou Driving Award x 4
